Frame rail repair
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mp4694330, Mar 28, 2016.
  1. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    Well, my 2001 lost battle with rust,I can poke it with screwdriver and goes thru ... any suggestions?Weld, bolt on or both? Maybe take everything off and clean/paint whole thing ?
    It's next to the engine on one side and shock on another.
    That hanger visible on pic is holding coolant line.
    Also buddy of mine advised, that I should fix one on other side of engine to avoid flex issues for future.
      File size:
      190 KB
      662
    New2D12, Johny41 and Straight Stacks Thank this.
  3. AModelCat
    164,678
    If your whole frame is in rough condition like that you might be better off having new rails installed. Kind of hard to tell condition from 1 photo. Might be possible to weld a new piece in and have a sleeve fabricated and installed on the inside for reinforcement. I would advise taking the truck in to a reputable frame shop to see what kind of options you have for repairing this.
    @BoxCarKidd any other ideas?
  4. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
  5. Ridgeline
    22,724
    123,383
    Replace the truck. Once it starts, it is going to be a fighting battle you will lose.
    Beside using now is a violation iirc and you will end up oos
  6. 201
    201 Road Train Member
    12,785
    26,306
    Apr 16, 2014
    high plains colorado
    Hi mp, clearly, replacing the truck may or may not be an option, and replacing frame rails is a big job, but not the worst. I had a frame rail crack on my Western Star behind the sleeper, and a shop bolted a smaller "U" channel inside the stock frame rail. It worked for a while, but then the repair cracked as well. I was told it was done incorrectly, and ended up cutting the back off and put a Peterbilt Air ride frame on it.
  7. mp4694330
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    Thank You all for answers so far, definitely safety is my biggest priority now.
    Anybody knows reputable shops in Chicagoland, heading to one now, but would like to get more estimates.
    @stayinback
    New2D12 Thanks this.
  8. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Your picture just looks like some bad surface rust. You say you can stick s screwdriver through it?
    mp4694330 Thanks this.
  9. Ridgeline
    22,724
    123,383
    There is a difference between a cracked frame and one rusting away, the cracked frame can be easily repaired to prevent it from spreading, but when they rust, it is almost impossible to keep up on making sure it is safe. This isn't thin sheet metal, it is thick metal that takes a beating and when it weakens from rust, then there are other issues that happen.
    mp4694330 and BoxCarKidd Thank this.
  10. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    Before you go nuts getting estimates think of this: A flake of rust say, 1/8 thick is probably only a few thousandths of actual material. Rust ALWAYS looks worse than it is.
    My advise to you is, acquire a needle scaler and knock off all the heavy corrosion before making any decisions. Most likely you could media blast the area after scaling and paint with a quality metal coating (not rattle can). Then have some plate bent up and bolted on as a reinforcement (with same size bolts as existing cross member bolts). Stay away from welding, welding is a "field fix" and not really correct for a heat treated frame.
  11. Mikesee
    Mikesee Light Load Member
    90
    51
    Oct 25, 2014
    I second the needle scaler. I got the smaller one from Harbor Freight and it works fantastically. Will take most of that rust off then paint. If it does go through the frame have the body shop address those areas. It may not be as bad as you think.
