Frame rail.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bernard D, Sep 7, 2020.
  1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    What would it cost out the door to replace both frame rails with a 330 in WBase.
  3. AModelCat
    164,387
    Probably a lot. KW quoted me something like $9k a rail for blanks. Add in the labour to drill and replace on top of that.
    Bernard D and alds Thank this.
  4. o1reb
    o1reb Bobtail Member
    49
    21
    Apr 28, 2012
    bedford
    there is a co in vt sells the rail punched to length 866 851 6478 P.G. Adams
  5. AModelCat
    164,387
    I had mine done locally for under $1500 for the pair. I cut, drilled and installed them myself.
  6. thejudges69
    thejudges69 Light Load Member
    246
    316
    Aug 22, 2015
    PG Adams sells rails. I'm gonna speculate you'll likely be 4-5k in rails drilled and they'll want a template to drill. Or you buy blanks for slightly less. Likely 3-4k. Add in labor for the replacement which will likely be 30-50 hours of labor at 100 an hour. Add in for incidental stuff, then drive lines if your not 330 already, then figure in the plumbing, and axle work. The list goes on. IMO I'd set aside 15-20k. It's a hug job to replace rails but very doable. Unbolt one side at a time, snag from the back and pull. I have a brand new sent of rails that will end up around 345" if I don't cut them. I've contemplated using them on mine since I'm currently 330" wheelbase.
    And if your not 330", be ready to learn to drive all over again..
    AModelCat Thanks this.
  7. AModelCat
    164,387
    Still worth it if the rest of the truck is solid. Typically after about 20-25 years the truck is ready for a re-rail.
  8. thejudges69
    246
    316
    Aug 22, 2015
    I don't know that I'd agree with that time frame. Wear and tear and how you take care of your equipment will determine a more suitable timeframe
    HoundDog7 and AModelCat Thank this.
  9. AModelCat
    164,387
    Most folks in the areas that salt/calcium chloride the roads in winter don't wash the frames often enough from what I've seen. Add in 100k+ gross they're on borrowed time by 25 years. I'd imagine they'd last much longer in the south but I've never been fortunate enough to experience that lol.
    Goodysnap Thanks this.
  10. thejudges69
    246
    316
    Aug 22, 2015
    Again I think I'd disagree. I'm in NE-Ohio and have many and known many running original rails from the 70's and 80's. Very common. I know very few guys who've done a retail due to age
    HoundDog7 Thanks this.
  11. AModelCat
    164,387
    Alot of my experience is on vocational/off road heavy haul stuff. I've never actually turned a wrench on any truck that was strictly highway spec'd so maybe that's where I'm seeing it differently.
