Frame ramps for 379
Discussion in 'Peterbilt Forum' started by Coolbreezin, Aug 9, 2022.
  1. Coolbreezin
    Coolbreezin Medium Load Member
    410
    440
    Jun 11, 2016
    Florida
    Hello everyone. I need to get frame ramps but I don't have holes in my frame for them to bolt to. I know we cannot weld or drill on the truck frame.
  3. AModelCat
    165,103
    Who says you can't drill the frame?
    Drilling the web (vertical portion) is perfectly fine. Drilling the flanges is a huge no-no.
  4. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    As he said above, perfectly fine to drill the frame.
    It can be welded as well if dine by a competent person.
    Especially way on the back of the frame where your ramps would go. What's the worst that would happen? Back of the frame falls off. Not gonna happen anyway
    Roger McG, Coolbreezin and D.Tibbitt Thank this.
  5. D.Tibbitt
    157,374
    I just added some ramps to my frame . now they arent the greatest but they get the job done for what it is.
    I used 3/16 bit to 1/2 inch to 3/4.. Slow and steady wins the race. You want brand new sharp bits. And drill nice and slow. Going fast is only going to burn up ur bits. Its a all day job if by urself. It took about 6 hours total. To drill the ramp holes into the ramps and then drill the frame out.
    3/4 inch grade 8 bolts with 3/4 inch grade 8 flange lock nuts
    cke and Coolbreezin Thank this.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    I would find a good tool rental store and rent a magnetic drill it's well.worth the rental if you value you time at all
    baha, Roger McG, cke and 2 others Thank this.
  7. AModelCat
    165,103
    Mag drill with an annular cutting bit. Take longer to set up each hole than to drill it.
    cke, Coolbreezin, lester and 1 other person Thank this.
  8. D.Tibbitt
    157,374
    Doing it by hand builds character :biggrin_25523:
    bigyellowjimmy, Roger McG, cke and 3 others Thank this.
  9. AModelCat
    165,103
    I did the entire frame from my cab back by hand.
    cke and D.Tibbitt Thank this.
  10. Deezl Smoke
    Deezl Smoke Medium Load Member
    543
    357
    Feb 12, 2011
    Hillsboro Oregon
    Coolbreezin, D.Tibbitt and AModelCat Thank this.
  11. AModelCat
    165,103
    cke, Deezl Smoke and D.Tibbitt Thank this.
