Freedomline transmission
Discussion in 'Volvo Forum' started by dtenney, Jan 17, 2012.
  1. dtenney
    dtenney Bobtail Member
    Gainesville, FL
    Thinking about buying a used 05 Volvo VNL670 with 600,000 miles running the VED12 Volvo engine at 465hp backed by a 12-spd ZF Freedomline transmission. Ideally I would like an I-shift but that requires an 08 or newer truck($$$ + DPF). My other option would be the Eaton Ultrashift, which seems clunky in comparison to the Freedomline on my test drive. I am concerned about being stuck on the side of the road without any knowledgeable service people since the Freedomline is no longer sold in the US. Any thoughts? Should I avoid the truck because of this transmission? Often times I am lightly loaded and would appreciate the skip shift feature of the Freedomline.
    Thanks,
    David
  3. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    Parts and service availability is always at the top of my list in purchase decisions. If I can't easily and consistently get parts I probably won't own it. This has worked for me with trucks, tractors. construction equipment, forestry equipment.
  4. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    I would look for a Volvo with a Cummins Engine if you are set on the Volvo 670. You will get better performance and better mpg with the Cummins versus the Volvo engine.
    KH
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ZF 12 st and I-shift share many parts, like clutch parts, actuators, electronic board....
    Mechanically transmissions are different but made in the same style and I cant say what tranny is better!
  6. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    if you can buy i-shift it is far better hardware than AS tronic
    you can drive volvo ishift like it is a racecar , it performs very smooth shifts and it is fastest gearbox on market
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I use to work on both and yep, mechanics say volvo box is better, but as I can see there is no notisable difference for driver.
  8. 98989
    5,990
    6,740
    Sep 14, 2008
    it is far better mechanically
    volvo ishift can be speced up to 200-250tons
    i have never seen astronic (12) above 90t and most of them are up to 70t
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there are three ore four different i-shift boxes of different torque rating.
  10. 98989
    5,990
    6,740
    Sep 14, 2008
    i know but still this is far behind astronic
  11. dtenney
    Gainesville, FL
    I am mostly trying to decide between the Freedomline and the Ultra-shift, the ishift is too expensive for my budget currently. I am leaning toward the Freedomline unless I hear a convincing argument to stay away. My loads would be 20K lbs to 60K lbs, normally loaded closer to 20K.
    -David
