Freight liner fl80 on gas
Discussion in 'Questions From New Drivers' started by Tiptruckongas, Jun 29, 2018.
  1. Tiptruckongas
    Tiptruckongas Bobtail Member
    6
    We bought a freightliner fl80 with a Cummins engine. It's aprox 20 years old and it runs on gas. Lately we've had trouble with it running. It stalls, and when it runs it seems to ' misfire' or something on occasions. It seems to have a mind of its own. Does anyone know what could be the problem or where in Melbourne I could get some advice?! As soon as I say that it runs on gas, no one can help me! Does anyone have any clues? Much appreciated.
  3. Dino soar
    Dino soar Road Train Member
    4,817
    27,071
    Dec 8, 2017
    I never heard of a Cummins gasoline engine.
    I'd recommend that you find a manual for it somewhere and do all the things that gasoline engines require like spark plugs wires distributor cap if it has one.
    If it is an OBD2 engine then you should be able to buy a tester to put into the diagnostic port and it should give you codes, that's probably a good place to start.
    But at least here the states, I've never heard of a Cummins gasoline engine.
  4. Colt6920
    Colt6920 Light Load Member
    178
    263
    Apr 28, 2017
    Gasoline or Natural Gas?
    What motor?
  5. Ridgeline
    22,774
    124,509
    It is a natural gas engine. The best place to get it fix is the dealer.
    rabbiporkchop Thanks this.
  6. FlyingA
    FlyingA Bobtail Member
    46
    23
    Jun 3, 2018
    Sacramento, Ca
    You can get shop manuals for the engine model. I worked on CNG Cummings motors here and they are not hard to fix. We had lots of problems with plugs going bad and coil packs failing.
  7. Tiptruckongas
    6
    Thanks I found a shop manual and You have definitely given me some. Ideas. Much appreciated
  8. Tiptruckongas
    6
    It's lpg natural gas. We're in Australia!
  9. Tiptruckongas
    6
    It's a Cummins engine but not sure what type. How do I find out. ? Thanks
  10. kemosabi49
    11,011
    48,101
    Jan 13, 2013
    SW Arkansas
    Should be a plate on the engine with that info.
  11. Tiptruckongas
    6
    Thanks but cannot see it??!
