Freight tampering done with seal intact
Discussion in 'Experienced Truckers' Advice' started by DONIZUKA, Aug 13, 2021.
  1. DONIZUKA
    DONIZUKA Bobtail Member
    4
    Aug 29, 2020
    Hello truckers,
    First off, thank you for your services!
    So I work for a freight broker and recently I had a load deliver in a dry van trailer with the seal still intact, but the freight inside was definitely tampered with...so I am assuming there are there ways of removing the janky thin metal seals, or trailer doors, or the lock mechanisms on dry van trailers? Any suggestions on security checks to prevent this in the future? Stronger seal type like a bolt seal obviously could help, but if there is a trick to get inside with seal intact anyway, then I guess it does not matter how strong the seal is?
  3. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Right, you just remove doors with hinges and seal will stay intact. Chicago carries are famous for this practice. Usually it's used for consolidating freight going to West Coast
    Lostmykey, buddyd157, tscottme and 3 others Thank this.
  4. tarmadilo
    tarmadilo Road Train Member
    1,733
    4,775
    Dec 12, 2018
    It’s very possible that the shipper gave the driver the paperwork and the seal and no one watched to see if the driver actually sealed the trailer. I know that often happens with my loads. Kinda defeats the purpose, but people are lazy.
    mustang190, tscottme, Tb0n3 and 7 others Thank this.
  5. buzzarddriver
    3,848
    11,666
    Feb 1, 2011
    Dallas, TX
    Spot weld the ends of all bolts on trailer doors, i mean everyone. Then use long heavy duty cable seals
    Heavy Duty Cable Lock | Cable Seals | American Casting
    Use the cables long enough to weave around door closure rods and through lock assemblies.
    The more difficult you make it, the less problems you will have. Thieves look for the easy targets.
    tscottme and gentleroger Thank this.
  6. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Tin seals can be removed easily removed and reattached.
    They are TIN the little tab will bend to open. Bend it back to reseal
  7. DONIZUKA
    4
    Aug 29, 2020
    Thanks DUNE-T...is there something warehouse can look out for in the future like looking at the hinges to see if they're tamper proof somehow?
  8. DONIZUKA
    4
    Aug 29, 2020
    our warehouse does take pics of trailer with seal on it, but yea def something to be aware of!
    tarmadilo Thanks this.
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Just make sure that you steal something REALLY EXPENSIVE!! :rolleyes:
    Snailexpress Thanks this.
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    If the load is worth the extra expense..
    Bolt type seals on both doors and require carrier to take pics of seals on doors prior to leaving shipper.
    Not fool proof, but it would put the burden squarely on the motor carrier.
    DONIZUKA and Dockbumper Thank this.
  11. Dockbumper
    3,778
    9,863
    Apr 29, 2020
    I pick up quite a bit of border freight. (southern). Many times there are 2 bolt seals, a long cable seal wrapped around the hinges on both doors, and sometimes "security tape" of some sort bridging both doors. I pick them up pre loaded at our terminals, so I am not sure of the chain of custody at the border. We are required to double check the actual seal numbers with the paperwork, and enter the info on our loaded call on the QC. The OP's situation sounds like it could be an "inside job".....pilfering on the docks. I know.....unthinkable with the boy scouts they have working those docks! Lol:rolleyes:
