freightliner 2012 cascadia attenna
Discussion in 'CB Radio Forum' started by bad wrench, Mar 27, 2012.
  1. bad wrench
    bad wrench Bobtail Member
    18
    6
    Feb 11, 2012
    How do you run attenna cable? How do you get the excisting cable?
  3. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    These new trucks that use the antenna for the AM/FM radio and the CB radio seem to be a real headache. The easiest solution seems to be mount your own separate dedicated CB antenna and run your own coax from that antenna to your radio. It may be ugly looking or not depending on how talented you are; but, it is a simple solution to the problem.
    cuzzin it Thanks this.
  4. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    KISS= keep it simple stupid .... is an old saying but it is the best way to go.
    Run a new coax cable for only the cb. Make sure you have good grounds. Some grounding point on trucks flex with road movement, so flexable grounding straps may be needed at a few key points from body the frame. A stright ground from the battery will save you a lot of headakes down the road.
    rollingradios Thanks this.
