Freightliner 2012 m2 with Check engine and STOP light on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rankin11, Mar 19, 2020.
  1. Rankin11
    Rankin11 Bobtail Member
    6
    My truck got the Check Engine light on last night. I drive about 200 miles after a few stops. My STOP light just came on and am worried. I put DEF yesterday at Petes. I had put some also last week but normally buy the containers from Wal-Mart or mostly Casey. The code showing is Diag 3 anyone with an idea what could be going on?
  3. Flint1
    Flint1 Road Train Member
    1,154
    9,880
    Sep 4, 2019
    Alberta
    Diag 3 is showing there is 3 active codes. Push and hold the button on the cluster until is beeps and moves into the code menu.
    You can then toggle thru the codes, there is 3 parts.
    1st is ecu, for example 128 is ECM
    2nd will be spn/pid
    3rd will be fmi
    Need all 3 to figure out, use search function when you do.
    Example ecu 128, sid 111, fmi 1 is low coolant sensor issue...
  4. Rankin11
    6
    Eng 0
    Fault 1
    Fault 2
    Fault 3
    Diag 3
  5. Rankin11
    6
    That's is what its showing once 1 Thru the details
    1569 spn
    Fail 31
    Fault 2
  6. Rankin11
    6
    Also seeing this codes
    Eng 0
    Diag 3
    Fault 1
    3360 spn
    Fail 9
    Fault 1
    Could you be able to help?
  7. Flint1
    1,154
    9,880
    Sep 4, 2019
    Alberta
    Need more info before anyone can help. Year, engine etc
  8. Rankin11
    6
    It's 2012 freightliner Cummins engine, m2,
  9. Rankin11
    6
