freightliner airliner bushings.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ristow, Feb 10, 2017.
  1. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    i gotta trashed bushing back there. will have new bushings in hand shortly. gonna do this myself,looks pretty straightforward task,but always open to insight from those that did it before. the old bushing will fall out,i just gotta get the old outer shell out. removal seems to be the hard part on these tasks,mine look like it made itself easy.
  3. Ridgeline
    22,741
    123,654
    I had to have mine pressed into the arm. BUT That was a 1999 FL.
  4. AModelCat
    164,921
    Those bushings are pretty easy to do. I always took the springs out of the truck and pressed the bushings out in the shop press. This is how I did it:
    Heavy frame stands or blocking under frame, dumped the suspension air. Unbolt air bag and shock. Then set up a floor jack under the spring. Then torched off the u-bolts (always seem to be seized) and unbolt the spring from the front hanger. Then pressed out/press in new bushing, reinstall in reverse order. Make sure to buff all the rust off between mating parts with a wire wheel or you'll never get the u-bolts to stay tight. In all honesty I would do all the spring and torque arm bushings as well as shocks. Those spring eye bushings don't hold up well and you'll have to do a wheel alignment after anyways. May as well rebushing the whole thing and you know it'll be good for a while. Its not a big job to do. I used to be able to completely rebushing a tridrive with airliner in a single workshift.
  5. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    yeah,im gonna try to do this one on the truck. later when i have more time i would like to remove the springs like you said,and put all new shock mounts on too. mine are trashed from the shocks coming loose. you may have seen the post about m,ine having stacks of washers for spacers. they seem to come loose. looks like the po was having the issue too. im sure thats what took the bushing out.
  6. AModelCat
    164,921
    You will need a bushing driver of some sort to drive the new bushing in but I think it's doable on the truck. I used to coat the outside of the new bushing with anti-seize to help it press in easier. Don't know if its right or not but it worked ok.
  7. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    yeah,all this stuff will get renewed this spring. im trying to come up with a way to push the bushing in. probably a couple pieces of iron,and a threaded rod through each end,and tighten the threaded rods evenly to bring the bushing through the eye.
  8. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    just press out/press in. if you have trouble getting the metal sleve out after the rubber falls out you can take a hack saw blade and cut a slit in it and it will come right out.
    if you don't have a shop press it might be a bit harder, maybe rig a bottle jack and press against the truck frame? or just go to harbor freight and get a press.
  9. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    i got access to the press. i got the ubolts needed coming too,with the bushings.
  10. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    i always cut the old u bolts off not worth the hassle of trying to get the nuts off. smart man getting new u bolts to start with. i normally have a local shop bend me up new u bolts whenever i need them tends to be cheaper than ordering and you always get the right ones.
    one common thing i have run across with the airliner suspension is keep a eye on the air bags the beams like to start walking and your notice the airbags start leaning, witch accelerates wear on the bushings when you notice that cut the u bolts off straighten everything back out and put another set of u bolts on.
  11. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    yeah,ive seen the crooked bags a lot. none of mine are doing that.
