Freightliner alarm syste
Discussion in 'Freightliner Forum' started by jacksonotanner, Feb 8, 2021.
  1. jacksonotanner
    jacksonotanner Bobtail Member
    May 28, 2020
    So I have a 2021 freightliner cascadia with the very annoying 4 digit alarm system in it. The one that you have to punch in the 4 digit code to be able to start the truck. It has suddenly stopped working. No red blinking light on it, and it isn't recognizing any buttons being pushed. Looking for a fuse that might have been blown or is there a way to just route around it?
  3. Flat Earth Trucker
    4,316
    16,622
    Nov 19, 2018
    Don't you worry. The good folks at Freightliner are making the same effort as our guy in image above.
    Hye Thanks this.
  4. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Ignoring the non-value post above...what is the last 6 of the vin? I'd be curious as to what wiring exists for this feature. And also if it was a PDI or CWO installed component.
    If I had to guess, I bet this is a fleet truck and they're the ones to have it installed...but I could be wrong. (which is why i wanna check)
  5. Flat Earth Trucker
    4,316
    16,622
    Nov 19, 2018
    Are you kidding? My posts are worth their weight in bacon.
  6. RocketyMan
    549
    337
    Jun 5, 2015
    @Flat Earth Trucker -_- ....LOL!
    Okay fine...gimme some bacon! This OP'r is a one (two) post-willie.
  7. Flat Earth Trucker
    4,316
    16,622
    Nov 19, 2018
    See there? Bacon solves everything.
  8. Irishblood_83
    Irishblood_83 Bobtail Member
    22
    7
    Jan 11, 2021
    Mine recently stopped working too. If you take the nobs off your brake releases and pull that panel off, behind it should be a set of wires with a fuse somewhere along it. I personally don't care for the alarm so I prob won't even replace it. Plus I'm having too many other electrical issues at the moment. Hope this helps.
