freightliner bus. class
Discussion in 'Freightliner Forum' started by E4GHT, Jun 8, 2021.
  1. E4GHT
    E4GHT Bobtail Member
    1999 M2 freightliner, lights will not turn off after shutting down. Only way to turn them off is with master switch beside battery box. Any idea what is going on here. Any help would be much appreciated.
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    I had something similar where the whole truck wouldn't shut off. I had the keys in my had and standing on the ground, outside the truck and the engine kept running. Only way to kill it was the master switch. Took it to the shop. There was short in the ground if I remember right. Its been a while.
  4. QUALITYTRUCK
    1,818
    1,783
    Jun 14, 2009
    romulus,mi
    Located either behind the driver front fender or on driver frame rail is something called a CHM (chassis module) Google it to get a pic. This module is what supplies lighting to the truck. When you unplug the connectors (6 I think) you will probably see much corrosion.
    RocketyMan Thanks this.
