Freightliner Cascadia 2013 DD13/ Fuel pump issues
Discussion in 'Ask An Owner Operator' started by Captain23, Feb 20, 2021.
  1. Captain23
    Captain23 Bobtail Member
    16
    8
    Feb 20, 2021
    Hello,
    I recently purchased a Freightliner Cascadia 2013 DD13 Engine. I’ve had the truck for 2 days & recently went to my local mechanic to do a PM Service. After doing so the truck had trouble starting, I understand certain. Times air can get into fuel lines of truck if filters were put on improperly. After 30-45 minutes we finally got the truck running and changed the filters again. It still gave some trouble but eventually it became steady. My mechanic told me my fuel pump is weak and it shouldn’t have taken that long for the truck to turn back on.. I purchased this truck from Penske. The truck has low miles and was a leased to a local customer throughout its life span. What can I do to make sure my fuel pump is isn’t bad? Any troubleshooting or advice l. Any beneficial advice would be really really appreciated!
    TRYING TO
    KEEP IT MOVING!!
  3. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    After fuel filter changing its common to have a hard start , normally takes a little driving . I have a 2014 FL and thats been normal . I read somewhere that it needs proper priming.
    Captain23 Thanks this.
  4. AModelCat
    164,921
    Did they pressure bleed the fuel system? Been mentioned on here numerous times that there's a special tool used to bleed the air out. I think 1 member on here mentioned they modified a garden weed sprayer for the job.
    Captain23 and sealevel Thank this.
  5. Captain23
    16
    8
    Feb 20, 2021
    Apparently They tried but the tool itself was broken.any thoughts how I could troubleshoot the issue myself.
  6. Captain23
    16
    8
    Feb 20, 2021
    The truck turns on fine now, but him telling me my fuel pump is weak is concerning me.
  7. AModelCat
    164,921
  8. Captain23
    16
    8
    Feb 20, 2021
    AModelCat Thanks this.
  9. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    My guess is he didn't know what he was doing and conviently blamed your fuel pump. He didn't do your system any favors. It's fine for now but you will remember him when it fails 100,000 miles from now. Learn as much about the little things as you can yourself, and watch anyone who touches your truck like a hawk.
    Had the same thing happen to me during a PM. Dude hooked his garden sprayer contraption to it. Would have worked fine if the moron had fuel in the sprayer. It was empty, and he proceeded to pressurize the system with air. You will be fine for now. Don't let him touch your truck again.
    Captain23 and LoneRanger Thank this.
  10. LoneRanger
    LoneRanger Road Train Member
    3,696
    9,608
    Jun 3, 2018
    I’m with this guy.
    Also I have the same issue when pm is done. Pressure tool never used, just one long start and I keep it running for about 50 miles, and no issues after that.
  11. Captain23
    16
    8
    Feb 20, 2021
    Appreciate your feedback, guy is notable in the area, and trusted him. I guess sometimes they like using a scapegoat when they screw things up. Going to start looking for a more reliable mechanic. He did spray start up fluid into engine breather a few times, now that worried me.
    sealevel Thanks this.
