Freightliner Cascadia marker lights
Discussion in 'Experienced Truckers' Advice' started by Keepontrucking2016, Dec 14, 2018.
  1. Keepontrucking2016
    Keepontrucking2016 Light Load Member
    170
    40
    Apr 7, 2016
    I'm planning on changing my roof marker lights do to water leak gasket behind markers are bad I'm guessing I tried to unscrew one of the marker lights and the screw keeps spinning is there a way to remove without damaging fiberglass roof
  3. STexan
    STexan Road Train Member
    14,963
    29,179
    Oct 3, 2011
    Longview, TX
    It’s probably your windshield gasket is bad or poorly installed. From Cascadia, this is almost expected. Even with the new 1-piece
  4. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I thought of that first butt I replaced it and they sealed it with rubber silicone or whatever you call it that's used for windshield
  5. STexan
    14,963
    29,179
    Oct 3, 2011
    Longview, TX
    Well good luck. The only way I was able to stop the leak in my previous truck was to retire it to the trade/sell line. They looked closely at everything except replace the windshield gaskets.
    The next new one’s leak was stopped with a replaced windshield due to crack at 4 months.
  6. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I sealed it around the marker lights will see if that stoppes it
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Sometimes if you use another thin flat blade screwdriver and wedge it under the head of the screw to pry the screw up, while you turn the screw with the appropriate screwdriver, you are able to get the screw to come out.
    Andreybanyuk, Dan.S, snowwy and 2 others Thank this.
  8. Keepontrucking2016
    170
    40
    Apr 7, 2016
    Ok I'll try that and see if it works thanks
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Can also use needle nose pliers.
    Use a bit of clear silicone on the light housing to stop leaks.
  10. MachoCyclone
    MachoCyclone Road Train Member
    4,417
    3,907
    Jun 13, 2012
    Texas
    If your Cascadia has a built in Sat Radio receiver; they are very prone to leaking. Never got mine to stop leaking on the '15 Cascadia.
  11. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I never thought about that I get up there and seal it too and see
