Freightliner century 2006
Discussion in 'Ask An Owner Operator' started by Luke700, Apr 30, 2022.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    The best description for this is that when the truck is off or recently turn off and your sitting in the truck maybe on the bed. You feel this thump almost sounds and feels like the driveline or something. Anyone ever experience this before ?
  3. rollin coal
    rollin coal Road Train Member
    13,620
    27,997
    Mar 29, 2008
    TN
    Maybe an air leak draining down your air bags and the truck creeping a little as it settles?
    Magoo1968 and RefMata Thank this.
  4. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    Mine was doing the same thing. Check for rust on the slip joints. There is some stupid plastic sleeve on it that traps water and rusts the shaft. This creates a bulge and the joint cant slide in and out smoothly.
    merv85 Thanks this.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    Do you set both brakes if so trailer probably dumps suspension air and pushes on truck kinda feels like someone bumped into you
  6. Luke700
    57
    26
    Oct 14, 2019
    So when the truck is off and you park the shaft moves after into like a sitting position ? I’m just curious more about it but this is an interesting video
  7. razor1983
    500
    509
    Jan 17, 2011
    If you have an air leak and the airbags drop, then it changes the driveline angle.
    I had that thump and bump for years, until I cut off that plastic and removed the rust. Also 06 Century.
    Even if thats not it in your case, I would still remove that rust because it can apparently cause vibration
  8. Luke700
    57
    26
    Oct 14, 2019
    I appreciate it
  9. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    Air bags dropping. I have the same truck
