Freightliner century turn signal issues
Discussion in 'Freightliner Forum' started by Nemotrucksllc, May 13, 2023.
  1. Nemotrucksllc
    Nemotrucksllc Bobtail Member
    The left turn signaland hazards stopped working. I thought it was the turn signal switch so I changed it still same problem..
    When I hit the switch theyll flicker a couple times then dim out. I checked the fuse it seemed to have some heat to it. Volt meter bounces a Lil when turning on the switch also.
    I've unplugged rear light light harness. Cab light harness and front light harness on that side and still same issue.
    Any ideas?
  3. Nemotrucksllc
  4. JB7
    JB7 Road Train Member
    1,040
    1,834
    Dec 13, 2022
    Laurel, MD
    Flasher. Other than that the wiring. Unplug both sides and see what happens. Unplug the right side only and see what happens.
  5. Nemotrucksllc
    Thanks for the reply. Where is the flasher? I found the fuse on passenger side dash but the fuse wasn't side dependant just single fused labeled turn signal. When you say unplug both sides your referring to light harnesses?
  6. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Upper left hand corner of PDM (fuse box) If original it will be a silver metal 2" x 2" square relay with 2 pins on it.
    JB7 Thanks this.
