Freightliner century
Discussion in 'Ask An Owner Operator' started by Luke700, Jul 8, 2022.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    At random my century shakes aggressively left and right like wobbling badly. It also I’ve notice react to every bad spot in the road.it’s just tough to control it sometimes. Cab shocks got changed. Front shocks/ rear. Alignment got done. Same issue. Gear box, steering shaft. Tires are new and in good shape. Would the front springs cause this? Would upgrading to the airbag front suspension make a difference ?
  3. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    Is it while accelerating?
  4. Luke700
    57
    26
    Oct 14, 2019
    I haven’t thought about that but I’ll Check but why if it was or not what would that mean?
  5. bad-luck
    bad-luck Road Train Member
    3,431
    6,321
    Nov 16, 2013
    Baltimore, Maryland
    Have you had the king pins checked?
  6. supergreatguy
    1,030
    2,896
    Nov 26, 2020
    I was chasing down bad vibrations under acceleration. Did everything, tires, pins, alignment, shocks, tie rod ends, motor mounts. Ended up being injector #1. Replaced all my injectors with harness and no vibrations since
    that’s why under acceleration is a consideration
  7. GreenPete359
    GreenPete359 Road Train Member
    2,248
    5,407
    Oct 21, 2017
    Driving my recliner
    To go along with the acceleration note, it could be also be a motor mount.
  8. Luke700
    57
    26
    Oct 14, 2019
    All my
    Injectors are new. Recent Inframe and motor mounts got changed about a year and change ago. I saw this YouTube video where someone was saying his springs was the issue because one side was lower than the other not sure
