Freightliner classic blower motor
Discussion in 'Freightliner Forum' started by Zeeny, Nov 17, 2013.
  1. Zeeny
    Zeeny Light Load Member
    54
    Nov 16, 2013
    Hi guys,I have a 2000 freightliner classic and the blower motor only works on #4,I changed the blower motor that was burned out and I also put a new resistor in it and still only works on. #4 only,anyone have any ideas.and also the voltage gauge drops down yo about 11 or so when I put the lights on.but the batteries are good and alternator both showing 14 volts with everything on,lights are bright and been starting with no problem at all ,could it be just a bad gauge.if someone can help thank you very much
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    ck. switch with test light to see if power is coming out at all settings, get alt. ck. with amp. test gauge.
    Zeeny Thanks this.
  4. Zeeny
    54
    Nov 16, 2013
    Is that a 2 stage switch or something
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    might have got a bad resistor out of box, just ck. if power is going to motor at all switch settings.
  6. Zeeny
    54
    Nov 16, 2013
    Ok will do thank you
  7. wore out
    wore out Numbered Classic
    17,483
    218,185
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If blower motor was in really bad shape I have seen the plug in on switch kinda melt due to motor drawing to many amps. Had an IH even get acc wire at key too hot from same thing. Just something to look at or think about.
    Zeeny Thanks this.
  8. Zeeny
    54
    Nov 16, 2013
    Cool thanks for the info I will deffinetly check thanks again,and that truck looks good
  9. wore out
    17,483
    218,185
    Jun 5, 2013
    The 359 belongs to me the 379 is my sons. Thanks we are proud of them.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Bad relay.
    Speeds 1-2-3 run off the same relay but 4 runs off it's own relay.
    Funny cause the hi-speed one is always the one to quit on me.
  11. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    Freight liner sells the whole harness for under $100 dollars. Found it to be that a few times. More disturbing is that the local dealer had two in stock lol.
