I have a Freightliner Columbia 2007 , my water temperature gauge was getting stock and not moving , I replace temp sensor but still no fix,
I bought a new instrument cluster from Freightliner dealer ,temperature gauge works perfectly but now my turn signal lights won’t work , I replace the turn signal switch and still not working , I decided to re-install the original instrument cluster, and to my surprise turn signal light works fine.
Any idea on what could be causing this issue
A bad ground should have the turn signal light not working on both instrument cluster right?
Freightliner Columbia 2007 Instrument cluster issues
Discussion in 'Freightliner Forum' started by Stevecarino, Jan 26, 2019.
