freightliner columbia keeps burning power distribution module
Discussion in 'Freightliner Forum' started by beleavchenko, Oct 28, 2018.
  1. beleavchenko
    beleavchenko Bobtail Member
    2007 freightliner columbia keeps burning power distribution module. what can be the cause, have replaced 3 already, will burn it with key in off position , truck parked. the 50 amps fuse under dash passenger side burned too, replaced it. checked for short, and didn't find any. any suggestions what can cause it to burn and where I should look?
  3. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Best guess is a leak with water intrusion somewhere.
    beleavchenko Thanks this.
  4. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    If you are talking about the auxillary PDM that is located in the driver side "b" pillar, then the cause is a water leak around the upper bunk window that leaks straight down into the top of the PDM. When you unplug the top 2 connectors you will see corrosion. Fix leak or put plastic bag around new PDM so that water cannot get inside.
    Rideandrepair and beleavchenko Thank this.
  5. beleavchenko
    I did found a water leak on wires and from the frame of the top window from sleeper, will try to seal it and hope it does the trick
