Freightliner Columbia -vs- Century Class
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gears, Feb 23, 2010.
  1. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,185
    Aug 20, 2009
    I know a ton of parts between these two models are interchangeable. I'm just curious as to what is the big difference between these two? Why would Freightliner make two trucks so similar? Am I missing something (aside from the obvious)?:biggrin_25526:
  3. ironeagle2006
    ironeagle2006 Road Train Member
    Columbia was for the Owner Ops thing is the Fleets like it as much as O/O's. Something about Chrome and the feelings it causes in drivers that could be why TMC has such an easy time HOOKING THEM IN. Must be that they give them a SHINY HINEY SKATEBOARD AND A PETE 379 TO BOOT IF THEY SURVIVE.
  4. Gears
    4,511
    3,185
    Aug 20, 2009
    Not to derail my own thread, but TMC uses Columbias? I've never seen that. I also noticed that they no longer seem to be using Pete 387's either. Wonder why that is...
  5. Hedon
    Hedon Light Load Member
    121
    95
    Jun 29, 2009
    SW Missouri
    Just talked to a couple of guys at two different Freightliners about this and was surprised to find out that the Century is considered the higher-end model over the Columbia. Who knew?
    They both said chassis, suspension, sleeper, and cab were pretty much the same except for the dash.
  6. Gears
    4,511
    3,185
    Aug 20, 2009
    Go figure. I've got the Century.... upper end? Who knew?...
    Watch out now....my ego's inflating.:biggrin_25522:.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Yes the Century was the more expensive model, I had 2 with Cat engines. The Century model had a different hood that allowed more air flow to go thru and come out on the sides where the hidden hood latches were. On a hot day when you had the window down, at slow speeds all you could feel was the engine heat.
  8. Hedon
    121
    95
    Jun 29, 2009
    SW Missouri
    I think we're getting ready to buy a Century ourselves... keeping up with the Gears... :biggrin_255:
  9. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    I guess I am at the bottom. Mine is a Columbia, Great to sleep in when it is shut off. LOL
  10. 1999blue
    1999blue Light Load Member
    92
    11
    Dec 27, 2008
    quartzsite,AZ
    Really enjoy my 2001 Century, but just had a code 45, Low turbo air,,,, Whats going on,,,, Any of you people had this fault??
  11. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    The Century's are a 100% better truck. Columbias are the stripped down version of a Century with alot less frills. Having driven both, stick with the Century.
