Freightliner Detroit engine 60- 2008 Engine Protect Warning
Discussion in 'Freightliner Forum' started by keepontrucking81, Jul 14, 2013.
  1. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    When the check engine/stop engine light comes on you can check the codes your self. You would have got 43, low water,
    Turn on the switch, and hold the override switch. Count the number of flashes for the first number of fault, then wait for a pause in the flash, then count the number of flashes for the second digit in the fault. Count the number of flashes until it cycles back around. Examples of codes would be 2 yellow or red flashes, then a pause, then 5 yellow or red flashes then a pause would be a code 25
    You may have a DDEC IV or DDEC V but many are the same.
    keepontrucking81 Thanks this.
  3. keepontrucking81
    keepontrucking81 Light Load Member
    210
    41
    Jun 27, 2013
    Chicago, IL
    What switches? Don't I need to get that diagnostic meter to see the codes?
  4. Old Man
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    The shutdown overide
  5. Roadruner
    Roadruner Bobtail Member
    Yo my truck la Columbia 2008 60 series. Tus morning starter the truck 3 mins after regen light on and of and check engine light come on and red check engine light and. Shut off the engine and starter on and run any body have. Idea w is the problem
