Freightliner Fld120
Discussion in 'Freightliner Forum' started by Franchise35, Jan 13, 2022.
  1. Franchise35
    Franchise35 Bobtail Member
    Jan 13, 2022
    Jacksonville, FL
    I have a question. I have dual stacks behind the sleeper of my 95 Freightliner fld120. For it's year it is Owner Operator spec'd but I want to remove the stacks from the back and move them behind the doors. What would I need to complete this job and is it better to do it myself or let the pro's handle it?
  3. F4T6UY
    F4T6UY Medium Load Member
    567
    1,807
    Oct 24, 2017
    Very South Texas
    I’m also curious what it would take. How do the brackets mount? What kit/brackets would be needed. Do you just use Classic hardware?
    Rideandrepair Thanks this.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    It’s just plumbing
    Some elbows. Brackets. A new set of $5,000 stacks etc
    Not an impossible job and if you can do any sort of mechanical work then I’d tackle it myself
    F4T6UY Thanks this.
  5. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    $$$ Probably new piping etc from turbo back. It can be done if you find an old FLD or Classic in the junk yard and buy the stuff there it would safe you a good bit. Hardest part will be mounting brackets on side of cab.
  6. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    I would leave it like it is. The next few years are going to be tough. Save your money for things you need (tires, engine repair, etc..) If your exhaust is working fine let it be. You will probably lose a little MPG on the sides as well. Plus your hearing.
  7. Rideandrepair
    17,560
    56,893
    Aug 8, 2015
    Having them out back is nice. Quieter all the way around. Even while parked and idling. Bunk is quieter.
