Freightliner making loud grinding noise!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BigO293, May 10, 2021.
  1. BigO293
    BigO293 Bobtail Member
    5
    Mar 28, 2021
    Hello, I am an o/o of a 2001 Freightliner Century class and lately it makes a loud grinding noise in the front of the truck when making an "L" turn left or right. It only happens when I am loaded and making an "L" turn. The steering wheel does not get hard when turning.
    I changed the power steering pump but it didn't fix the problem..
    Any advice on what it can be is truly appreciated!
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    What is "L" turn left or right? I do not understand.
    Bean Jr. and AModelCat Thank this.
  4. AModelCat
    164,848
    Tires not rubbing against anything?
    Not sure what an "L" turn is either?
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK the ft. spring bushings they can wear out so much after years of wear that they let the springs shift and rub?
    BigO293 Thanks this.
  6. BigO293
    5
    Mar 28, 2021
    Sorry about that. By a L turn I mean a sharp turn like in an intersection in the form of an L.
  7. Joyce's Volvo
    Joyce's Volvo Light Load Member
    116
    153
    Jun 28, 2016
    Jack up the front axle and check for slack or noise in the bearings , sounds as if you got a bearing starting to flake ( failure). Any slack or noise - pull it and check bearings and races for Pitts ( flaking ), any flaking- replace both bearings and races , replace the seal while your in there .
  8. Rideandrepair
    17,571
    56,913
    Aug 8, 2015
    Did you change the filter for PS system?
  9. BigO293
    5
    Mar 28, 2021
    I did not. Where would that filter be located?
    Rideandrepair Thanks this.
  10. Rideandrepair
    17,571
    56,913
    Aug 8, 2015
    Usually inside the reservoir, at the bottom, held by a bolt or nut.
