Freightliner power steering problems
Discussion in 'Freightliner Forum' started by Halfpint504, Jul 14, 2017.
  1. Halfpint504
    Halfpint504 Bobtail Member
    8
    Jul 14, 2017
  3. Halfpint504
    8
    Jul 14, 2017
    No problems turning left or right with truck jacked up.
  4. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    Sounds like a STEERING GEAR. "Box" is way too ambiguous.
    You'd need to hook up your PSSA gauge and verify your flows and pressures to determine if the steering gear is relieving or not and then how much it's leaking past the seals. Then you can make the assessment for steering gear and/or pump. Any certified FTL dealer will have access to the STI492 form that lists out what things to check as well as the workshop service manual to follow the procedures.
    You weren't overloading your front axle...were you?
    Halfpint504 Thanks this.
  5. Halfpint504
    8
    Jul 14, 2017
    Not overloading axles as turning to the left is nearly impossible even bobtail ing.
    Replaced the water pump, hoses, filter and fluid, not the king pins nor any front end problems. Gotta be the box! Process of elimination. Thanks for your help and suggestions.
    baha Thanks this.
  6. Sergio Alfaro
    Sergio Alfaro Bobtail Member
    10
    Jul 1, 2018
    Did it finally got fixed? and what was wrong at the end?
  7. Texasdude10
    Texasdude10 Bobtail Member
    Mar 29, 2019
    Any update on what solved the issue.? I have the same problem
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    I’ve heard of a problem like this, that finally turned out to be the slip joint in steering shan’t binding. Driver ( after replacing everything else) replaced the shaft. Problem solved. Hope that helps
    KB3MMX Thanks this.
  9. Rstenicc
    Rstenicc Bobtail Member
    Half pint what fixed it? I have the same issue with my 2016 cascadia.
  10. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    I’d like to know also. There’s a thread on here about 2-3 mos ago. Same problem, it turned out to be slip joint in steering column
    KB3MMX Thanks this.
  11. 2hot2handle
    2hot2handle Light Load Member
    67
    34
    Aug 25, 2015
    Isn't there a pressure relief valve for both sides that needs to be set so when you turn full lock it doesn't create to much pressure? Maybe that went bad.
