Freightliner Special Oil Pan Plug
Discussion in 'Freightliner Forum' started by Freightisgreat, Jun 26, 2024.
  1. Freightisgreat
    Freightisgreat Bobtail Member
    18
    5
    Mar 25, 2023
    My new to me Freightliner has a spring and ball in the drain plug. Is there a special hose or end you can screw into the plug to drain the oil?
    austinmike Thanks this.
  3. austinmike
    137,938
    All I know is don’t F it up. It’s not an easy fix
    nikmirbre Thanks this.
  4. Freightisgreat
    18
    5
    Mar 25, 2023
    I see there are different brands of drain plugs with check valves. Are the drain hose threads the same, or are they all unique to the brand?
  5. OlegMel
    OlegMel Medium Load Member
    613
    1,038
    Apr 8, 2023
    Spring and ball sounds like someone installed aftermarket valve for easier drain or because they didn’t want to remove drain plug every time…. Try google search to find the type that you have…
    I know in my truck I have a fitting that I screw into the drain plug and it releases the valve and the oil drains
  6. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    At the shop we would have big fleet trucks that came in that had a type of quick drain installed. We didn't have that system so we just removed the quick drain just like you removed a drain plug. The most common type could be removed with a shallow 1-1/2" socket if you removed the dust cap first.
  7. Freightisgreat
    18
    5
    Mar 25, 2023
    It's a former Ryder truck. Is there a certain brand Ryder uses?
    Rideandrepair Thanks this.
  8. Rideandrepair
    17,562
    56,898
    Aug 8, 2015
    It’s just a aftermarket quick drain plug. There’s a couple different brands, and a couple different configurations. Each one is engine brand specific. Mine has a nipple, I keep it capped and put a hose on it when draining oil. Comes in handy when changing your own oil. Draining it directly into empty jugs. Old DPF 2.5 gallon jugs work great. The valves are available at some Dealerships. Im sure you can find them online easily. My guess is a trip to the plumbing dept at your local hardware store with the valve in hand, you cam find a nipple and piece of hose to fit it.
