Freightliner stop engine and check engine light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tmichael2332, Jun 20, 2015.
  1. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    So what ended up being the problem? I am having the same issue..I can't find a leak but keep having to add antifreeze left and right..am going to try to keep it at max level see if that helps. She's been doing this for about the past 150 miles..now it's pouring rain and keep having to pull over
  3. DeepSouthRollin
    DeepSouthRollin Light Load Member
    82
    55
    Apr 14, 2018
    louisiana
    unbelievable...but its probably TRUE !!
  4. Truckers Report Jobs
  5. Sidekick77
    Sidekick77 Bobtail Member
    4
    Have a 2012 cascadia..through a 3364 fmi 1..3364 fmi 17...checked everything found out performing def quality test no def is getting to one box..what do i do
  6. Sidekick77
    4
    I hve that problem as well but def light blinks. I found out no def is getting to one box
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    2012, that would have the air operated DEF pump and Doser. The Doser assembly could be clogged. Can be disassembled and cleaned with just water.
  8. gf f t
    gf f t Bobtail Member
    I have a 2011 frieghtliner cummins engine that got a busted pressure hose and that was repaired but now the check engine light and the stop light turned on and it won't move/start. how can I fix it?
  9. mojohammer
    mojohammer Bobtail Member
  10. mojohammer
    my stop engine light came on and i did a forced regen and it went off. drove a few miles and it came on again. i’ve had a crack in coolant reservoir for about a year and have to replace about an inch everyday. decided to change it and everything is perfect now.
