Freightliner sucks over RR and potholes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sergk1989, Sep 9, 2019.
  1. sergk1989
    sergk1989 Bobtail Member
    39
    10
    Jan 23, 2013
    Freightliner Columbia with airliner suspension
    New tires perilli
    New shocks Gabriel
    Does anyone know a fix to this problem?
    Running bobtail and hitting bumps or rough railroad my truck feels bottomed out and everything hits hard in the interior
    With a trailer it’s a lot better but still...
    Ride height seems to be ok I get no vibration driving down the road
    KB3MMX Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,579
    6,675
    Aug 26, 2014
    Air ride cab?
    KB3MMX Thanks this.
  4. LoneRanger
    LoneRanger Road Train Member
    3,700
    9,628
    Jun 3, 2018
    Could be leave spring bushings, im having same issue in cascadia, but I’m replaced front shocks with original freightliner, Gabriel’s suck, and will replace cab shocks next week, hopefully and then leave spring bushings.
    KB3MMX Thanks this.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,373
    Mar 13, 2009
    Did you try replacing cab mount bushings and cab shocks yet?
    Working2party Thanks this.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Yep, check your front cab mounts the originals don’t like rough things and like to blow out. They make an HD version. It has alittle rougher ride but they last forever. I’ve had to change all my Coronado SD’s over to the HD cause the trucks run in rough areas and the commission paid drivers just won’t slow down.
    This usually starts with a loud thump (sounds like it’s coming from the driver side, but is usually the passenger side that’s out) when hitting rough stuff. I’ve never been around one that had both out. if that’s your case, I’m not sure how it will act.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You have to take it easy on the equipment.
    The Driver absolutely decides how much damage the truck will take, if any.
    KB3MMX, bzinger and stillwurkin Thank this.
  8. Rideandrepair
    17,587
    56,970
    Aug 8, 2015
    Yep. The passenger side usually goes bad first. Due to heat from Exaust.
    KB3MMX and shatteredsquare Thank this.
  9. shatteredsquare
    shatteredsquare Road Train Member
    1,409
    1,845
    May 23, 2014
    middle dirt
    Where are those cab mount bushings located? I'm guessing there's 4 of them, one per corner?
  10. bzinger
    bzinger Road Train Member
    16,665
    66,248
    Dec 10, 2014
    omaha , ne
    Slow down ! It's a truck not an army tank .
    KB3MMX, Matt1924, Nukem and 1 other person Thank this.
  11. shatteredsquare
    1,409
    1,845
    May 23, 2014
    middle dirt
    Once it gets fixed I'll save the trail braking for the bike, having fun is too expensive in these things
    KB3MMX and bzinger Thank this.
