Freightliner with turned up c12
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Jan 23, 2021.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    Just purchased 99 freightliner with a turned up cat c12, with no transmission. Question is should I put 9 speed transmission in it, or an 8ll since I do alot of off road on rough terrain and about the same or lil less on surface streets
  3. Tanksmuch
    Tanksmuch Light Load Member
    102
    181
    Jul 22, 2019
    Central Arkansas
    I'd say an 8LL if it has to creep under load. The C12 is (in my opinion) the best mid size Cat engine ever made, good on power and fuel, but it's not a torque monster. Probably perfect for the terrain you're talking about.
  4. ETMF 58 White
    ETMF 58 White Light Load Member
    90
    219
    Jan 4, 2019
    8LL with a C12 and 3.90 to 4.10 rears is excellent for a dump truck has been my experience. Light weight engine, and LL gears will really crawl off road, but can go 65 mph on the highway easily too. The only down side I had was old OTR drivers weren’t in the habit of using the LL gears and didn’t understand the concept of what we were trying to do.
    Brettj3876 Thanks this.
  5. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    My truck that I drive all the time (out of 3 I own) is a 2000 Freightliner FLD with a C12. Amazing engine! 500k miles and going strong! Not sure about trans but I love my 10 speed.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    I would skip a 8ll and go for a 9ll if you want crawling speed,
    if you will do alot of highway and hills jump to 18 speed, same low as 8ll but can split gears, which will help mileage and steep pulls.
    Lowest gear ratios
    8ll 14.56
    9ll 26.01
    18 speed 15.06
    Tanksmuch Thanks this.
