Freon capacity for 1988 Peterbilt 379
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vgarza32, Mar 11, 2023.
  1. Vgarza32
    Vgarza32 Bobtail Member
    19
    28
    Feb 27, 2018
    Needing the Freon capacity for a 1988 Peterbilt 379 with flat top sleeper. Has 4mg b model cat. Trying to dial the ac system in. Any help would be greatly appreciated. I’m figuring around 4lbs but wanting to know an exact number that it calls for. Peterbilt is being as worthless as tit on a boar at the moment.
  3. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    There is no exact amount of R134A for a R12 system. Suggest starting with 75% of the R12 amount. Open both doors, set on fresh air, make engine fan and compressor run continues, engine RPM at 1200 or so. Put a thermometer in the dash air discharge. Add freon at about 4 OZ or 20 PSI increase on high side and let stabilize. Keep adding freon until the temperature no longer drops and you are done.
    That takes a little time but 4 OZ can amount to 10 degrees in some of those 134 conversions.
    Rideandrepair Thanks this.
