Freon swap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BigRig1980, Apr 28, 2020.
  1. BigRig1980
    BigRig1980 Bobtail Member
    27
    10
    Feb 26, 2020
    What should we do to change the old r12 to r134a in the 1987 357 Peterbilt. Will I need a new compressor drier pressure switches or just hook my machine to it and pump it down and refill with 134a? Just want it to function is all.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    from what i did back in my garage days was to change out the high side/low side charging fittings (usually come in a kit), and drain out the old freon and the compressor oil too as well.
    new/fresh oil, and R-134 filled to specs.
    we never had to change over anything else, but maybe the receiver/drier (basically a filter)
    but too, that being such an old truck, there can be and very well may be seal leaks around the compressor pulley and at many connections, (look for lots of caked on dirt at all these places) so be prepared to do a leak test, with a leak detector, maybe even dye. but you need a full charged system for good results of the testing, so a little to a lot of freon will be wasted.
  4. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    If I remember right: all you "need" is the kit with the new ports for the low and high side to hook up the gauges. Everything else will work but for best efficiency the 134 systems have a larger condenser in front of the radiator.
    Edit: what @buddyd157 says
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    I thank the older Petes did OK with the R12 condensers and 134A.
    If you can turn the compressor by hand might want to do an extended vacuum. Then see what it does with some freon in it.
    I would do a complete flush and dryer as a minimum but you do not even know if your compressor builds pressure.
    Search block- top right.
    BigRig1980 and Rideandrepair Thank this.
  6. BigRig1980
    27
    10
    Feb 26, 2020
    Nothing greasy or dirty on any of the lines or condensor
    Rideandrepair Thanks this.
  7. BigRig1980
    27
    10
    Feb 26, 2020
    So just hook robinair Freon recovery unit and pull how much vacuum
  8. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    when it is pulling a vacuum, it will "level off" on it's own. then you shut off the vacuum, and watch the gauges. an incredibly slow rise will indicate a tiny leak, some wheres in the system.
    a sudden sharp rise in the gauges, will indicate a larger leak.
    then you'd have to recharge the system, with a dye, run the a/c, you will also need a black light to located the leaks.
    and using a "sniffer" have to go to each and every fitting, the compressor, etc, and when the "sniffer" alarms goes off, there's your leak.
    you want to do this leak test during calm weather (NO wind), or in a garage, NO running fans..!!
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The dryer must be changed even if it looks new before the change over to late model freon! If it still has the old stand/up york type A/C comp. buying a adaptor plate and buying a jap. made rotor type a/c comp. will make it blow ice cold.
  10. Rideandrepair
    17,575
    56,939
    Aug 8, 2015
    The only real difference is the fittings. You can use a newer compressor, w/o fittings, but will need to change lines to lines with fittings. Or use the old style w/ adapters. The conversion kits had a 4oz. Can of oil. It was either pag or ester oil. Whichever one, it was supposed to be compatible. Bottom line, use correct oil. I’ve been using oil, w/ green dye for a while. Makes finding a leak very easy. Vacuum rule of thumb is 30 lbs, for 30 minutes. In reality 28-29 lbs is all that’s possible, I usually pull one for 45 min- 1 hr. Then let sit for 30 minutes making sure it holds a vacuum. I would check the availablilty of original compressor. If it’s no longer available, might want to upgrade it now, along with new hoses, or adapter manifold with new port fittings.
  11. AModelCat
    165,007
    R134a has smaller molecules. It will permeate thru the R12 hoses.
    Apparently the R12 condensors don't work as efficiently with R134a either.
