i had a pete with a factory fridge/freezer in it. I switched companys and now i have my 1000watt inverter hooked up. I have a koolatron thermo electric cooler but they suck. If i put a small dorm fridge in there will a 1000 watt inverter run it and if i shut the truck off for a 10hr break will it run without draining truck battery? Im out of options. Any suggestions would be nice. What are you guys using?
Fridge questions
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by jtaran06, May 25, 2012.
![[IMG]](proxy.php?image=http%3A%2F%2Fwww.dometic.com%2FFileOrganizer%2Fproductimages%2Fportables%2FCoolFreeze-CDF-18.jpg&hash=e41a404f469a8e74e5b755e9b3587307)
Super-compact, favourably priced entry-level compressor cooler. With performance and handling qualities that will ensure you will enjoy it for years to come.
A flyweight of a compressor cooler with an empty weight of just 11.5 kg, and convenient to transport with the sturdy carrying handle: the new WAECO CoolFreeze CDF-18 offers a full 18-litre capacity for snacks and drinks. This is due to the units optimised inside and outside dimensions and to the compact design of the high-tech compressor.
In terms of performance, the CDF-18 qualifies as a true heavyweight: refrigeration and deep-freezing up to 18°C at minimal energy consumption! -
I wouldn't count on it running for 10 hours without the truck running. If your in it just idle. No one will say anything to you.
jtaran06 Thanks this. -
I have a regular Emerson dorm fridge. Compressor start is 150 watts and quickly drops to 70 watts where it runs maybe 3-5 minutes every half hour or so. I always shut it down on hometime, but I bet it would run 24 hours without hurting anything. It uses about the same as a TV and I can watch that 8-10 hours before hitting low voltage.
But I'd say you are safe for 10 hours. They don't run constantly.
APU with a 2500 watt inverter is the ultimate setup.
Those 12V coolers scare me. When I first started trucking I had a small one and woke up in the middle of the night choking when the cab filled with smoke. The cooler was a melted glob. I quickly threw it outside. I never owned one since then.
Depending on your truck, cabinet removal is an easy option to make room for a dorm fridge. I wish my laptop didn't crash. I'd show you a picture. I took the door and one side panel off. The fridge fit in perfect and I put the microwave on top of it. About $180 at Target. I've had it 4-5 years now. Great little fridge.
Im not worried about idling the truck..i was just curious how long they lasted with truck off...i guess im gonna get one. When i leave monday i will let it run till friday.
