Fridge questions
Discussion in 'Experienced Truckers' Advice' started by PermanentTourist, Feb 18, 2017.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    I just bought my first truck and I want to install a real fridge in it. Like one with the freezer and real compression Freon type Cooling.
    I have a little $80 fridge now that runs on an electronic fan, and it really sucks. Barely keeps things even slightly cool, and seems to eat way too much juice doing it. I don't like to idle if I don't have to, and that fridge cuts off within 5 hours of being parked.
    I know they have special expensive custom fit fridges for Cascadias -
    Do they work well?
    Do those consume less power?
    Do they actually keep running through a typical 10-hour break?
    Does anybody know where I can get a good deal on a used one maybe?
    And are they easy to install myself?
    Any answers appreciated, thanks
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    They are not cheap. You ideally want a unit that runs on 12vdc (Dometic). If you don't have an APU and you have 4 truck batteries and don't idle, such a fridge probably would never get you into trouble except for maybe long weekends at home or extra cold starts after maybe 24 hours
    You can look at https://www.iowa80.com/browse/refrigerators/COOLERS/ or various RV supply houses for install models. The
    HaulinCars and PermanentTourist Thank this.
  4. bzinger
    bzinger Road Train Member
    16,657
    66,201
    Dec 10, 2014
    omaha , ne
    I have a truck fridge model t49 for sale in Omaha ..can't even get an offer on it .
  5. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    How many beers will it hold?
    SidewaysBentHalo and bzinger Thank this.
  6. bzinger
    16,657
    66,201
    Dec 10, 2014
    omaha , ne
    Hmmm stack em right about an 18 pack lol ..plus some food .
    SidewaysBentHalo and tucker Thank this.
  7. SidewaysBentHalo
    SidewaysBentHalo Medium Load Member
    518
    697
    Jun 19, 2016
    You got other options. Alot of drivers who dont take passengers opt to have the extra seat yanked.
    Thats what i did. Put a 2.7 cu ft in. Relatively cheap. Walmart and home depot and other chains sell variations.
    Take measurements. Get a small 2inch strap with a single hook to secure it in using the seatbelt anchors to the floor. I probably could have went a little larger bit my fire extinguisher is mounted right by the door.
    Hindsight tip get something with a full top shelf freezer. Also no glass shelves. They rattle when empty.
    This is all assuming you have an inverter.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Engel fridges are really good on power, not cheap. Will freeze. Mostly cooler style designs.
    Dometic makes standard truck fridges that will fit your truck. I've only had power troubles when the batteries get old and weak. A standard ten hour break is normally not a problem.
    I have used household bar or apartment fridges that are 120 volt via an 1,800 watt inverter. Pure sine wave inverters work best. Do not use any smaller of an inverter as the fridge compressor requires way more power to start than it does to run. I know people that have used this setup for years without trouble.
    HaulinCars Thanks this.
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Remove the lower cabinet behind the driver seat. Walmart and harware stores sell $160 - $180 hotel/dorm style mini fridge with freezers. They work perfectly.
    I have my Microwave and Fridge behind the driver seat. Freezer full of hamburger meat, steakums, frozen veggies, ice cream etc. Fresh Veggies in the crisper,.. lunch meat, cheese, potato salad, slaw, mayo etc. The door will hold 8 12oz cans. Perfect for cooking your own food while out on the road.
    Hurst
    Boattlebot, Bean Jr., Ooops and 6 others Thank this.
  10. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    How much do you want for it? Do you have the Freightliner mounting bracket?
  11. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    you never got back with me on model/pics/or anything. So I figured you sold it.
