Frieghtliner century classic: question
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Jul 9, 2023.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Do these trucks have DEF?. I've seen some listed in the mid 30k range. Apperently they where manufactured from 1996 to 2010.
    Which I'm guessing means they have the EGR system.
    Also I haven't seen a horsepower listed, I'm currently in a 415Hp engine. Do they have more than that?
  3. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    From 1996 to 2010 they could have came with a variety of engines and HP and the early models would NOT have had any type of EGR system. Could be cat, cummins or Detroit. And power levels from 300 to 550.
    Bean Jr., 77fib77 and Rideandrepair Thank this.
  4. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Ok thank you. I will work on narrowing it down.
    Rideandrepair Thanks this.
  5. jamespmack
    04 and later detroits had EGR. Isx had egr, CAT, I can't answer.
  6. zmster2033
    zmster2033 Light Load Member
    190
    251
    Apr 28, 2011
    Charlotte, NC
    I believe CAT was ACERT (Advance Combustion Emission Reduction Technology).
  7. Blu_Ogre
    Blu_Ogre Road Train Member
    8,570
    51,387
    Jul 14, 2013
    Out west
    Real basic rundown would be based on EPA requirements for engines.
    I think it was EPA2004 that requires EGR.
    EPA2007 was when DPF was put into the mix.
    EPA2010 was SCR/Def introduction
    Engines may sit in storage for a bit so you could find a 2005 truck with a 2004 engine. and then there a gliders out there.
  8. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Nice
  9. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,916
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Drove a 2000 century with a Detroit. No def. Probably the best company truck I ever drove.
    Vampire, Numb, Rideandrepair and 2 others Thank this.
  10. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    Why worry about EGR anyways? It's a pretty easy thing to fix or make fall off
  11. Blu_Ogre
    8,570
    51,387
    Jul 14, 2013
    Out west
    Because deleting the EGR is a violation of the Federal Clean Air Act? And the EPA has been going after and shutting down shops that do the deletes or sell kits.
    https://www.overdriveonline.com/bus...rcement-put-the-brakes-on-illegal-engine-mods
    In theory shops are not supposed to release a truck with an illegally modified emission system until it has been repaired.
    Better to purchase a truck with an emissions system you are comfortable maintaining.
