From beautiful to ugly and back !
Discussion in 'Flatbed Trucking Forum' started by pavrom, Aug 21, 2022.
  1. pavrom
    pavrom Road Train Member
    3,224
    7,460
    Apr 29, 2012
    NE illinois
    What you guys think !
    Things(different word should be there ) happens ! First available repair appt end of September!!!!
  3. JonJon78
    JonJon78 Road Train Member
    7,245
    43,244
    Jul 1, 2018
    How did this happen? You have bad luck with conestoga.
    Bean Jr., FerrissWheel, CAXPT and 3 others Thank this.
  4. pavrom
    3,224
    7,460
    Apr 29, 2012
    NE illinois
    Another guy with dry van was backing into the spot :(
  5. JonJon78
    7,245
    43,244
    Jul 1, 2018
    You making him pay for repairs correct?
  6. pavrom
    3,224
    7,460
    Apr 29, 2012
    NE illinois
    His insurance ! He said he will pay out of his pocket under 1500-2000 ... Seemed like a stand up guy ... Report filed , insurance filed also ... Sucks to wait that long and drive looking like $$$eet
  7. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    https://www.amazon.com/Vinyl-Tarp-R...locphy=9012040&hvtargid=pla-592254102874&th=1
    Or you can grab a big bottle (or 2) of clear heavy duty PVC glue from the hardware store, and like 3 yards of PVC fabric from a craft store or maybe even Walmart. I've always used old tarps and cut to size. I'd probably get a helper on the inside with a strip of plywood so you can apply pressure from the outside while putting on the glue. I'd also probably grab a 6" foam paint roller or something instead of using the small dipper on the cap of the bottle.
    If you buy the Amazon kit, it looks like they're pre cut in 1 yard lengths, so it would be several patches seamed together. The glue is probably better than the stuff you get a the hardware store, but I've had good results with the clear heavy duty from Home Depot.
    The superhero music is optional when doing the repair.
  8. pavrom
    3,224
    7,460
    Apr 29, 2012
    NE illinois
    I used 3/4 plywood in the inside , rubber tape and plates with screw ... Seems like i can tight it up as much as i can ... Repair shop advised zip ties and gorrilla tape and barely tight it ...
    Another Canadian driver, cke and CAXPT Thank this.
  9. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    I had exactly that happen to my conestoga in McPherson, Kansas not too long ago. I punched a bunch of holes down each side and used zip ties. They went over it with gorilla tape. It was ugly, but it got me to our yard where they replaced the panel.
    CAXPT, cke, OLDSKOOLERnWV and 2 others Thank this.
