Front Axle Air Suspension
Discussion in 'Volvo Forum' started by 58Skylane, Apr 12, 2018.
  1. 58Skylane
    58Skylane Medium Load Member
    388
    276
    Mar 31, 2012
    Cody, WY
    Does anyone know if the front air bags are adjustable? For an air ride suspension, it sure seems way too stiff to me and way too bouncy. Shocks are fairly new and look good.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Yes the valve it’s self you can loosen it and put it higher or lower but you will mess with ride height
    58Skylane Thanks this.
  4. 58Skylane
    388
    276
    Mar 31, 2012
    Cody, WY
    Ok. I’ll mess with it and see if it makes any difference in ride quality. Thanks
  5. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    How many miles on the new shocks?
    Careful adjusting lower, you will change caster. You should have it put back in with a wedge from a competent alignment shop to do it right after lowering..
    Rob100100, Jazz1 and 58Skylane Thank this.
  6. 58Skylane
    388
    276
    Mar 31, 2012
    Cody, WY
    Less than 70,000 miles on the shocks. They are cheap enough, so I’ll start there first and replace them.
    KB3MMX Thanks this.
  7. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Check the bottom bolts on the shocks and see if they have any play air ride front everytime i change shocks i change bolts and nuts to some reason they always seem to get loose if you do not change them out.
    KB3MMX, 58Skylane and Rob100100 Thank this.
