Front Suspention VN 670
Discussion in 'Volvo Forum' started by waltherz, Dec 16, 2012.
  1. waltherz
    waltherz Light Load Member
    128
    12
    Dec 12, 2012
    Volvo 04 vn 670 have any sensor or system that inflate or deflate front airbag when is loaded o unloaded ? my question is because after unloaded any load, the truck is so regid on the highway. I replaced front air level valve and i not feel any improvement. Thanks
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,629
    Oct 11, 2010
    Borispol, Ukraine
    if you have level valve - not. only on trucks with ECAS pressure sensor is used, but.... for dashboard axe load indication
  4. waltherz
    128
    12
    Dec 12, 2012
  5. waltherz
    128
    12
    Dec 12, 2012
    Front axle with airbag. When air gone completly and truck is empty, after system get air, is very soft for drive. But after unloaded never return to soft point, remains hart or rigid. I use michelin 22.5 low frofile with 110 psi .
  6. gregor
    gregor Light Load Member
    90
    19
    May 13, 2011
    chicago,il
    dont know if you found out already but that means air height level is to heigh , take a measure tape ,unhook frrom trailer, charge air system to full, put truck on level flat ground, take a measurement from the bottom of leveling valve bracket to the bottom of the air bag ( black plastic bell ) it should be 7 7/8 +\- 1/8 ,be patien and good luck
  • Draft saved Draft deleted
