Frying my finals
Discussion in 'CB Radio Forum' started by HillbillyDLX, Sep 20, 2011.
  1. HillbillyDLX
    HillbillyDLX Bobtail Member
    46
    12
    Jul 8, 2011
    east texas
    I have had a Cobra 150, and a Ranger Cb radio. Both of which I installed, both of which, Ive been told, the finals fried up.
    Any idea what the cause might be? Is it the power supply, antenna?
    Dont want to make the costly mistake again.
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    BOTH ?
    Who told you this and was either radio modified ?
  4. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    The Cobra 150 & 200 are known for finals failing when running them on high power. That's why Cobra stopped making them. But you could have a antenna system problem. Since you burn up both radios.
  5. HillbillyDLX
    46
    12
    Jul 8, 2011
    east texas
    As far as being modified, they both were peaked and tuned, thats about it. Had my 150 looked at at the radio shop in Tulsa. They replaced the finals in the 150, and they blew again. Went back and they cut me a deal on the Ranger. Installed that and blew the finals in that too.
    I'm really nervous about buying another "high power", even something like a Cobra 29 with a mod kit. Hate throwing money out the window.
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    its not the radio, if you have had 2 diff radios do the exact same thing. usually it is high swr that blows finals. check your whole ant system out with a good wr meter, and see what they are, should be under 2.0, preferrably around 1.5. hope this helps.
  7. Happy_Hamer
    Happy_Hamer Light Load Member
    140
    40
    Aug 28, 2011
    Illinois
    Check everything AFTER the radio.
    Are you running an amp? Check the jumpers to the amp. Are you running external swr/watt meter? Check the jumpers to them as well.
    Is the amp ok? are the meters ok?
    Check the coax to the antenna.
    Check the antenna mount and the nylon washers on the mount. Check the condition of the antenna.
    I would NOT spend one more dime on another radio until you KNOW FOR SURE all the above is ok.
  8. Happy_Hamer
    140
    40
    Aug 28, 2011
    Illinois
    Let me add one more possibility that I have seen before,
    I seen a guy mess up his radio finals because he had dual antennas and hit a tree with one. He decided to just remove the broke antenna and leave the good antenna as is,,,,,,you need both antennas hooked up if you have a co-phase harness
  9. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    You're good! Wish we had more like you here! (I remember you from another forum)
  10. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    There are 2 simply ways to have blown finals. Blown finals refers to the power transistors are damaged. This condition will seriously limit your ability to transmit for distance.
    First, operate the radio without having a real cb radio antenna connected. No, you cannot use a rabbit ear TV antenna or something else.
    Second, operate the cb radio with a SWR reading, measured with an external meter, that is 3.0 or higher. Do not trust a meter in a radio.
    A SWR reading on the meter of 3.0 or higher indicates a connection problem. The easiest two things to check are bad antenna and bad coax. Borrow a known good antenna and coax from someone and re-check the SWR using an external SWR meter.
    If it is not the antenna or coax then the problem is the antenna ground plane is faulty.
    Please tell me that you are checking your SWR with an external meter before you operate your radio. Right?
  11. this_is_nascar
    this_is_nascar Light Load Member
    101
    25
    Jun 25, 2008
    Gloucester City, NJ
    Burn-out finals are 99% of the time caused by a bad-peak or tune job. Someone probably attempting to jack things up more than they should have and there you go. The probably tried to volt the finals.
