Fudging weight
Discussion in 'Flatbed Trucking Forum' started by m16ty, Jul 18, 2018.
  1. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    What do y’all say, move the 5th wheel up a couple of notches and run it?
    I’ve got a blanket for TN, so I’m not worried about that,but haven’t run heavy in GA in a long time.
  3. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    5th wheel up a few notches would spread the weight but you're over. Good luck. This week is safe driver week, they're yanking people into the scales at record rates. I went through GA not long ago and the scales were hot.
    Do you have a functional APU on board?
    stwik and Oldironfan Thank this.
  4. MACK E-6
    50,089
    238,984
    240 lbs is likely not a real big deal. I’d go with your idea.
    You weigh with full tanks?
    x1Heavy Thanks this.
  5. Tb0n3
    Tb0n3 Road Train Member
    4,739
    9,657
    Oct 5, 2012
    Earth
    If you have an APU you should get some extra on the 80k.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Move your fifth wheel ahead 2 notches and go. How much fuel you got on when weighed?
    Woodys and Oldironfan Thank this.
  7. m16ty
    2,274
    4,964
    Jan 22, 2016
    1/2 tank of fuel. The truck is now sitting at our yard, so I can dump all my extra chains and whatnot and think I can get under gross. Don’t know if I can get the axles perfect though, there is nothing more I can do to the trailer tandems.
    I could just permit it, but we are moving this same load 4 times from Nashville to Atlanta and back, during the next few months. Just don’t want to go with the aggravation of permits if I don’t have to.
  8. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    I think every tandem notch is roughly 300 lbs? Unless nose is "Doublestacked",then maybe no hope for "sliding it out". That Georgia is scary? Brings back memories of "Deliverance",watching Burt Reynolds ,act "Rugged " in a scuba top? WTF was that about? Unless youre "born and bred there,Cousin of the Prosecutor etc...Never shown much "leniancy" there.Couple hundred pounds ...if you can" burn off some fuel" or "slip thru" at 2am. May be OK.JMO
  9. AlBig
    AlBig Light Load Member
    145
    52
    Apr 16, 2017
    Yep 5th up. And losing 60 gallons of fuel will bring you too legal
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Get your drives as close as you can and you should be fine, don't know if Mr DOT would see it my way though.
  11. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Slide some of it forwards and play the fuel game.
    stwik Thanks this.
