Fuel Caps leak!
Discussion in 'Freightliner Forum' started by ReeferOhio, Feb 11, 2014.
  1. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    I know this is a common problem with Freightliner, but has anyone found a solution to the leaking fuel caps? I can't stand the leaking fuel and the look of my tanks. :biggrin_25510:
    barroll Thanks this.
  3. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    Rubber ring seal inside cap can be bought at parts store>
  4. xsetra
    xsetra Road Train Member
    5,200
    7,156
    Aug 21, 2011
    I was given the advice to file the very top lip. The neck will get scratchs and dents when the fuel nozzle is put in the tank. The rubber seal is to rigid to comform and fill the little grooves made by fuel nozzle. I decided not to try this because I don't want the fililngs in my fuel. I just wipe the tank everytime I fuel.
  5. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    911
    Mar 16, 2013
    Put a rubber O ring in the cap
  6. 07shaker
    07shaker Light Load Member
    201
    740
    Jan 12, 2013
    Tx
    I was just thinking of asking the same question and someone beat me to it.:biggrin_25519: Mine has rubber seals and I actually changed them awhile back with only slight improvement. I wish I would have kept the old ones and put two in each cap. Dont know if that would be too thick though.
  7. ReeferOhio
    596
    557
    Nov 29, 2010
    It has the gaskets in them, I bought two new ones, and they still leak! I've been paying attention and notice a lot of freight liners have leaking caps. I can't stand my tanks looking like this.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    If you have a groove in the neck, there is a square cut o-ring that goes in it. The problem is that the groove gets beaten up over time and wont hold a the o-ring for very long. The caps also have a flat rubber, so if you could make it flat, it seals OK. I've had some limited success filling the grove in the tank neck with JB Weld and filing it flat. It works until the cap chips away at it again. It would last a while for an O/O who is careful, but it only last a few months for our fleet drivers who slam the caps on. Just stuff a big rag in the hold 1st, so you don't get anything in the fuel.
    The only other option I know of is to find a welder than can replace the necks. If anyone has a better solution, I'm all ears, I have 4 trucks with this problem.
  9. ReeferOhio
    596
    557
    Nov 29, 2010
    Thanks for the post! Although an old thread, I doubled up the rubber gaskets and it stopped my leaking caps. For the most part. I will defiantly check these out. Do you use them?
  10. Hulld
    Hulld Road Train Member
    2,884
    6,569
    Oct 19, 2015
    Upstate NY
    If you have non lockable spring loaded twist on caps there is a cheap fix that works perfect and you can get it in about any auto parts store.....
  11. ReeferOhio
    596
    557
    Nov 29, 2010
    and that would be...
