Fuel cuts randomly. 98 w900
Discussion in 'Kenworth Forum' started by irishluck09, May 28, 2022.
  1. irishluck09
    irishluck09 Medium Load Member
    330
    200
    Nov 24, 2019
    98 w900l n14
    Randomly maybe 1-3 times a day my trucks cuts out Randomly like it's not getting fuel. Only does it for a fraction of a second and usually getting on it or pulling a hill.
    Fuel tanks are full. Just replaced fuel filter last weekend. Checked the small filter screen as well.
    Any thoughts on what to check?
  3. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Caterpillar? Cam position sensor.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,931
    Apr 10, 2012
    Indiana
    Said n-14 so cummins
    bigguns Thanks this.
  5. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    I see it now. ‍♂️ I believe there is a sensor similar on a Cummins. Possibly.
  6. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Could be an electrical issue like ecm loosing ignition power, cam position sensor issue or dead spot in throttle pedal. does it do it when in cruise control mode?
    A quick pause in power like you describe I would be looking at an electrical problem.
  7. MacLean
    MacLean Road Train Member
    1,385
    4,118
    Sep 12, 2017
    Had a DD16 in a company Coronado that would do that. Driving down the road and it would shut down and you’d pull over and start right back up and go. It’ll suck but start looking for a broken wire in the harness.
  8. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    It does have a cam position sensor tucked nicely in behind the air compressor. 5/8” deep socket. Cut a notch out of it. Then you can get onto the sensor and back it. Check the wires closely as they get oil soaked back in there.
