Fuel/Def dash gauge malfunction
Discussion in 'Freightliner Forum' started by habfleet, Sep 9, 2017.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    I have several Freightliner Cascadia's 2013 w/ISX/15 engine. I have replaced this gauge several times sometimes within less then a month is there a manufacture problem with these gauges .I am replacing them because both the DEF and Fuel indicator will fluctuate the def will show yellow or red lights even with the tank filled. If you tap on the gauge it will work fine for a while . Which leads me to think it is not wiring problem. Thanks in Advance .
  3. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,128
    Jun 3, 2015
    You should check the fuel sensors on the tanks.
    My guage did the same. Fuel levels became odd and at times, one would be full of fuel and the other dry.
  4. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    It's separate sensors
  5. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
    Loose connection.
    mhyn Thanks this.
  6. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    In 6 diffrent trucks ???
  7. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    yes. j1939 link is loose. the wires coming from air pressure gauge . that air pressure gauge has bad connector. fixed on many trucks.
  8. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    What was the fix Thanks
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    put the def/fuel gauge next to odometer. hook up the cable to odometer . the other cable must go out from def/fuel gauge to air pressure gauge.
