Fuel Efficiency Older vs New
Discussion in 'Experienced Truckers' Advice' started by JohnAyala999, Jan 9, 2024.
  1. JohnAyala999
    JohnAyala999 Bobtail Member
    37
    22
    Sep 22, 2022
    Hey so If you’ve seen my other post I’ve been looking into buying a truck in February and I’ve decided I think the older truck 00 KW W900L 550hp 3406E would be the better choice however I am not informed enough on the newer engines like isx paccar etc and my question is how much of a difference is there in fuel mileage between let’s say a 3406E and a ISX 15? Or a dd15 vs series 60. Just gathering as much information before I even think of throwing some dollars and i greatly appreciate all the extremely helpful advice y’all have been giving me on my last post
    Just for some info I will be hauling 53’ flatbed General Freight Mostly in Texas and will be staying under 80k GVW so mostly normal highway grades and sometimes some city roads as I’m passing through nothing crazy again thank you for the information truly
  3. Sons Hero
    Sons Hero Road Train Member
    3,038
    31,143
    Jan 8, 2021
    Indiana
    Buy the CAT. It won’t do better than 6 mpg on fuel, but it will be faaaaarrr more engine than a DD15. We have 1 DD15, and it isn’t terrible, but I would drive my CAT any day over a Detroit. If you want a Detroit, get a 12.7 Series 60. They are peppier than the 14 liter series 60, and the Jake’s are significantly better. They are great engines as well, but my bias is toward CAT
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Doesn’t necessarily have to do with the engine, but if you’re looking for efficiency, you gotta have a drivetrain for the engine to be efficient. Doesn’t matter what engine it is. Just looking at fuel efficiency, the A26 Navistar does rather well with an Eaton Endurant overdrive transmission and 2.64 rears, low pro 22.5s. But if you have an A26 with an 18 speed and 4.11 gears, all the efficiency goes down the drain.
    Rideandrepair Thanks this.
  5. JohnAyala999
    37
    22
    Sep 22, 2022
    Yeah definitely thanks for the advice
  6. JohnAyala999
    37
    22
    Sep 22, 2022
    Ok it is 3,55 gears
  7. tscottme
    tscottme Road Train Member
    Fuel cost will be your biggest expense, whatever truck you buy. A slight difference in average mpg will make a big difference,.
    There are guys that will spec a truck to drag elephants uphill and then claim they get better MPG than a fleet spec truck on flat ground. Don't believe it. I've seen guys with big motors for triple digit trucks claim they get better MPG than a fleet spec truck doing 65 mpg. Don't believe it. Don't buy more truck than you need. NOBODY is going to get better MPG speeding than they do at 60-65 MPG. Physics doesn't lie or wear a big belt buckle.
  8. Cat sdp
    Cat sdp . .
    21,304
    76,204
    Apr 8, 2012
    Orion's Belt
    Just get the borg spec Cascadia like everyone else
    400 or 450 DD15, 12 speed auto and 2.nothing gears…….
    8 mpg so they say…….
    JolliRoger, Rideandrepair and W923 Thank this.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    3.55 with what transmission?
    In a w9 and driven not with a lead foot assuming youre about 65+/- 2mph and hitting the right rpm band, i would expect 6 mpg (low/no idle) if the engine is running right.
    Could be as bad as 3.5 mpg with a lead foot, wrong rpm/trans/high idle
  10. cuzzin it
    cuzzin it Road Train Member
    3,641
    12,488
    Jan 19, 2008
    Berea, KY
    8.5 with the D12 turned up over 2+ yr period with that pos 12 sp auto. Keeping it out of 12th on hills
    Rideandrepair and OlegMel Thank this.
