fuel filter or air in line problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Aug 19, 2011.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    hey guys i changed out my fuel filter and was not thinking and did not fill it with fuel it started up but shut back down then started again and now i have a little pop sound from time to time like it air in the system some where...is there a way i can prime the pump and clear air if thats the case??? i plan to put and new filter on this weekend and fill it this time for sure...cummins m11 i didnt have the problem until i changed the filter out thats the reason im thinking air in 1 or the other...mike
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Well, remove filter and fill it with fuel.
    No need to put another new one on.
  4. earthmover
    563
    20
    Jan 27, 2009
    yea i thought about that also but i got it off might as well put a new 1 on ..also thought about it my have a air pocket in it from not having the fuel init when i started it...so what do you guys think i should do first??? mike
  5. STisma
    STisma Bobtail Member
    13
    Aug 17, 2011
    Midwest
    Add fuel in the filter, don't need the new one, and give it a start.
    Crank it for 5sec than rest for 30sec. Do it again.
    DO NOT overdo the engine starter.
  6. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    the starter should only be cranked for a max of 1 min or you risk overheating it. i would 1st try take filter off fill with diesel, before you crank over engine, loosen fuel line to injectors about 1/4 turn, follow small steel line that goes from fuel pump up to the head ( the one closest to the radiator) . crank engine over, when it starts loosen fuel line a bit more until deisel flows out and engine starts to run smoother, then do up fuel line and let engine finish sorting itself out..
  7. earthmover
    563
    20
    Jan 27, 2009
    i dont have a problem with the truck starting its just got a little pop every now and then under load and i think its fuel cause i didnt have the problem before ...im driven the truck everyday but would like to get this pop took care of...i turn the key hit the button and it fires like always no problem...sorry if i didnt give enough info at first guys..mike
    im thinking it has air trapped init somewhere since it only does it sometimes..
  8. rollin coal
    rollin coal Road Train Member
    13,617
    27,992
    Mar 29, 2008
    TN
    Do what Aussie Dave says.. that will bleed any air out of your fuel system
  9. earthmover
    563
    20
    Jan 27, 2009
    thanks guys gonna do it right now
  10. earthmover
    563
    20
    Jan 27, 2009
    well guys got it done and ran great for a well then strated to do it again..could it be the filter is bad????it dont do it all the time...i took the line loose 2 times and tried to make sure i got it out but guess not....
  11. mrdevildog
    mrdevildog Light Load Member
    75
    22
    Feb 23, 2010
    Heber Springs, Arkansas
    could be a bad fuel filter, whats your fuel pressure???
