Fuel Filter Vac Gauge
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gravelhauler, Feb 12, 2024.
  1. gravelhauler
    gravelhauler Medium Load Member
    630
    414
    Oct 20, 2011
    Lake Charles, La
    I have a 2006 Pete 379 with a C15 MXS Cat. The fuel filter vac gauge is reading 12 to 12 1/2. Truck is running and pulling great. Any ideas on what could be causing that?
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    At 12 I am sure its it's in the red. I change mine when it gets in the red. Trucks that don't have a fuel restriction guage, generally are changed when noticeable power loss or sputter occurs. In my opinion it's best to change it before power loss and sputtering, so you don't have to change it on the side of the road.
    gravelhauler and PSM379 Thank this.
  4. gravelhauler
    630
    414
    Oct 20, 2011
    Lake Charles, La
    So basically the fuel filter vac gauge acts as a warning that your filters are getting bad? I was just wondering if anything else would cause it to climb.
  5. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Yes that is correct.
  6. AModelCat
    164,801
    Any restriction in the fuel system prior to where the gauge is plumbed in will show up on the gauge.
