Fuel gauge
Discussion in 'Freightliner Forum' started by Scvready, Aug 30, 2018.
  1. Scvready
    Scvready Light Load Member
    231
    173
    Dec 16, 2017
    Louisiana
    Why does the fuel gauge needle never show full? It's like that on other driver's Freightliner not just mine.
  3. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    It will, eventually.
  4. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    There is an adjustable float on top of tank remove the three or so screws and adjust by bending rod as I remember or if you can move float up on rod. But you will also change the empty reading that is you may run out w/ gauge showing good. Only other reason is if tank is turned. That case losses straps and turn so float mechanism is on top . You can’t miss it usually on drivers side has wire running to it
  5. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    I should clarify it could always be the gauge. My guess is you can probably run a while on empty as is. I would leave it alone better this way than risk running out of fuel
  6. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Mine shows full for about 25 miles then its down to 7/8 of a tank. It's a useless gauge.
