Fuel gel
Discussion in 'Questions From New Drivers' started by Commuter69, Nov 2, 2016.
  1. Commuter69
    Commuter69 Road Train Member
    1,143
    635
    Jul 2, 2014
    I know that this is to keep fuel from freezing in cold temps. Does it need to be put in if I am in that kind of climate stopped without the engines(truck and reefer) running for a 10 or 34 hour break?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Sir Fuel is winter blend these days., Keep that engine running, some fuel is returned to the tanks to keep it all warm.
    Gelling happens at around 5 below if allowed to sit cold long enough. Ive had gelled fuel before when one tank was accidently shut off by the mechanic the previous weekend. Engine quit when the other tank drained dry and left us with jello in the other tank needing to be dumped and refilled all around. A task that took many hours.
    I would not add anything to fuel without speaking with your shop supervisor who answers to the owners or board that decides what you can and cannot do with the truck assigned to you. You could be held liable for ruined engines or other issues too number to count.
    Tall Mike Thanks this.
  4. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    It is not called "Fuel Gel".
    'Jelling' is what happens to your fuel in extreme cold temperatures if your fuel does not have an additive or is not blended.
    And yes...if it's cold enough, your fuel can jell in as little as 10 or 34 hours.
    My-Ke and x1Heavy Thank this.
  5. northernhopper
    northernhopper Light Load Member
    260
    367
    Mar 15, 2015
    isanti mn
    Depending on where you run it may get cold enough to to gel blended winter fuel. I use #1 50/50 with blended fuel to make my own blend when im near 0 degrees and colder. Im not really sure additives do much but i use them anyway. Its cheap compared to gelling.
    Yeah i know. Here come the dont use #1 people. They can do as they wish. This has worked for me for with trucks and construction equipment and my pu
    x1Heavy Thanks this.
  6. TripleSix
    133,739
    I had fuel jello happen in Saskatoon at the Hook, on the fuel island. Usually, it starts right at the fuel filter. I had a bowl type filter and could see it. Kerosene saved the day. If youre just taking 10, leave the truck running. If youre taking a 34, better use the block heater to keep that crankcase oil warm.
  7. Moose1958
    Moose1958 Road Train Member
    15,299
    33,968
    Dec 17, 2010
    Williesburg, Virignia
    Best way I know of to stop an APU in winter is don't use a fuel additive. I always every other fueling got a bottle and poured half in one tank half in the other. People sometimes forget how small those APU fuel straws are.
    archangelic peon and x1Heavy Thank this.
  8. sawmill
    sawmill Road Train Member
    3,962
    72,633
    May 29, 2015
    Evanston, WY
    Here's what I have found to work here in WY:
    Running: just use blended fuel, no additive down to 10 degrees. 1/2 bottle per tank under 10 degrees
    Engine off: 1/2 bottle per tank under 25 degrees. 1 bottle per tank under 0 degrees. This will be good down to at least -20. If it's colder than that it's best to let it run, although with 1 bottle per tank it's usually no trouble to start up down to -35.
    I don't know if brand makes a difference. I was buying Power Service by the pallet for about $10 a bottle.
    Some say you don't need it at all but I found that it's cheap insurance compared to wasting half a day trying to get it started if you forget to put it in.
  9. My-Ke
    My-Ke Light Load Member
    I'm so surprised I've never gelled up. I always hear stories about it. I don't idle AT ALL, no matter how cold it gets. I've parked in deadly North Dakota colds overnight and never had an issue. My malfunctioning bunk heater didn't even run continuously.
  10. archangelic peon
    archangelic peon Medium Load Member
    504
    376
    Dec 15, 2011
    Our company banned us from using Howes anti gel as they have supposedly had too many gel up issues with it.
    My buddy in a Peterbilt 384 had his fuel filter gel up tight twice even though he would dump two large bottles of the Howes into the tank religiously.
    We use a large Power service white bottle on fuelup for all 3 tanks + a bit of red bottle mixed in colder areas & apart from the odd -20+ night where bunk heater gels up due to uninsulated small fuel line, never have any problems with truck, reefer, & APU.
    x1Heavy, texasbbqbest and My-Ke Thank this.
  11. My-Ke
    You drive for Prime Inc?
    texasbbqbest Thanks this.
