Fuel Injector - Broken Electrical Connection Bolt
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jeff1288, Nov 3, 2018.
  1. Jeff1288
    Jeff1288 Bobtail Member
    8
    11
    May 8, 2014
    Fuel Injector - Broken Electrical Connection Bolt on c15 acert what suggestions replace the hole injector or any other way to fix
    jt road hammer Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Solenoids are replaceable. If it has a lot of miles probably better to just replace injector.
    Heavyd Thanks this.
  4. Mattwms
    Mattwms Bobtail Member
  5. Mattwms
    I replaced injector but accidentally broke a stud off of the solenoid, is there any way to remove the stud? Where can I get just the solenoid?
  6. wore out
    wore out Numbered Classic
    17,326
    215,175
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The stud doesn't come out.....you may get a solenoid at CAT but I bet it won't be in stock
  7. Cdemars316
    Cdemars316 Road Train Member
    1,031
    6,656
    Nov 10, 2018
    Reviving a very old thread here, is there anyway to soder the connection for one of the studs, or should I just wait for a new solenoid?
  8. wore out
    17,326
    215,175
    Jun 5, 2013
    Wait for a new solenoid. I
  9. Cdemars316
    1,031
    6,656
    Nov 10, 2018
    Yeah, I am going to, tore it apart this afternoon and figured out how to get the solenoid off, pulled one off an old injector I had, and ordered a new one in case this don't work out
  10. Cdemars316
    1,031
    6,656
    Nov 10, 2018
    Ok so now I am at a loss here, got a new solenoid and I am getting a miss on anything other than idle, truck ran normal for about three miles in a test drive now I can't get it to stop missing in my driveway, have removed the solenoid multiple times, tried other solenoids from old injectors, all do the same thing. The only thing I can think of is a problem in the wiring since its been moved around now, might try a new harness on monday.
  11. Cdemars316
    1,031
    6,656
    Nov 10, 2018
    Ok I figured it out, took it back apart and realized the little spacer or whatever you call it between the spring and the solenoid wasn't there, checked the old solenoid and it was stuck to that, so cleaned everything up and put it all back together and it runs good now.
    Heavyd Thanks this.
