Fuel is black
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gudethangs, Jan 6, 2015.
  1. gudethangs
    gudethangs Bobtail Member
    23
    Dec 14, 2014
    My fuel is black--like the exhaust got in there somehow. Got a Davco bowl with a Det. 60. Engine sputters & puffs smoke going up hill in low gears. Just change EGR, cooler, delta p sensor. Still same. Any thoughts?? Thanks
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    re you saying looking in the tank its black? Or are you looking through the glass of your davco fuel filter?
  4. 25(2)+2
    18,759
    45,983
    Sep 18, 2006
    the road less travelled
    You have microbes growing in the fuel. You will probably need help dealing with this, just putting in the biocide products will leave you with a fuel system plugged with sludge, unless you got a charge of bad fuel somewhere recently.
    It's called diesel algae by some, but it's actually fungus or bacteria.
    Cottonmouth85 Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Look in fuel tank, with engine running, at fuel return line area. If it is bubbling like a low pressure air hose in a water bucket it could be bad injector seals. Be sure there is no air in fuel lines entering head.
    clausland Thanks this.
  6. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    It's Algae, dump Power Service Bio Clean in it NOW!!!!!! Get several fuel filters, you'll go through them till the algae is gone.
  7. gudethangs
    23
    Dec 14, 2014
    Thanks for all the advice. It's in the tank as well. I don't see any bubbles inside the tank but then again it's difficult to see inside the tank. I'll give that bio clean a try.
  8. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Carry several extra filters and a wrench. Put some clean fuel in a can so you can fill your filter before putting it on.
  9. 123.Red Beard
    123.Red Beard Bobtail Member
    49
    37
    Jan 4, 2015
    Cochise County, AZ
    Also run it as low as you dare ... Then only put in enough for the day, treat again ... Takes awhile for it to grow, so if your fuel is gonna sit for awhile, you need to treat it!
    Most marina's have treatment on hand ... Also a tad a gasoline will kill it too, but new computer systems don't like gasoline! ;)
  10. hatlesstrukr
    hatlesstrukr Light Load Member
    128
    30
    Jan 30, 2010
    El Paso, TX
    Touch the black residue..
    If slimy, you have algae
    If gritty, you have an air leak in the fuel system
    dustinbrock Thanks this.
  11. gudethangs
    23
    Dec 14, 2014
    Replace all my injectors...no more black fuel
    driverdriver Thanks this.
