Fuel line diagnostic
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Handy, Apr 2, 2019.
  1. Handy
    Handy Bobtail Member
    16
    7
    Nov 14, 2018
    I have a 2000 kw 900 with a c-15 cat. I removed all my fuel lines and installed a new transfer pump. Now I can’t get fuel to flow. Truck was running fine prior to me messing with it. If I take the return line off fuel filter housing and pump the helllout of it with hand pump I can get a dribble once in a while. Does any one have a diagram of fuel lines? I must have mixed them up somehow under the sleeper where T fittings are. The line fittings appear to have different sizes so hard to mix but here I am. How can u tell which line coming out of tank is pulling and witch one is returning?
    Doealex Thanks this.
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    the bigger line is pulling
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    If it where me, I would look towards what was changed first.
    The lines were changed with the same sized fittings so that’s hard to mess up.
    A transfer pump thought?? Pumps are usually built with bi-directional housings. Have you checked that the lines are plumbed into it the correct direction? And it’s not not out of the realm of human nature that the transfer pump itself was put together wrong and is checking the fuel the wrong direction.
  5. Handy
    16
    7
    Nov 14, 2018
  6. Handy
    16
    7
    Nov 14, 2018
    The pump has two different size lines also so hard to mess that up. I can’t get any traction with the hand pump. Just tried a different hand pump and still nothing. If I take Filters off and fill them the pump will take a little of that fuel and push it through the head then dry up. This is a first start of an inframe and I don’t really want to use starting fluid. There is fuel in the tanks. There is a Y junction where the lines come out of the tanks and splice into the line going to the engine. Maybe it makes a difference how those lines tie together. Maybe a one way valve and I have the lines King the wrong way.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I use a air vacuum evacuator pump to pull fuel up when I change hoses. You could put less than 5psi to the fuel tanks to push the fuel to the primary filter.
    BoxCarKidd Thanks this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    One problem I saw like that was bad fuel filter. Truck was just serviced and drove to the wash rack. Left and ran about a mile and shut down. Primary fuel filter was bad and sucking air where it is crimped together.
    spsauerland Thanks this.
  9. 6NZoom
    6NZoom Bobtail Member
    39
    13
    Feb 4, 2019
    British Columbia
    Was wondering if you solved your fuel line issue?
  10. Handy
    16
    7
    Nov 14, 2018
    Thanks for asking. It helps others to share the solution of a problem
    I worked around the problem. I was stressing a bit with the no start because it was the first start on a complete in frame. Replacing the fuel lines should have waited until after I had it running. But I eventually tightened down all lines and gave it s shot of either and it fired up. The hand primer pump still won’t pull fuel from the tanks. If I fill the filters it will push fuel through the head but that’s all. I replaced everything including the secondary filter housing back to the tanks But I have put 16000 miles on engine so far with no issues. It runs like a champ. C-18 cam and c-16 injectors give it an edge on a hill and of course a nice plume of black smoke going through the gears!! Move over Junior!!
    wore out Thanks this.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Next time you change lines like that, leave the filter a little loose, or open the vent and shoot a little air in the tank vent, till fuel starts running out, then use your hand pump.
