Fuel Mileage
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Brian_CEM, Mar 30, 2021.
  1. Brian_CEM
    Brian_CEM Bobtail Member
    4
    I'm curious what everybody is getting with their set up.
    Mine:
    2014 Pete, 9 car cotrell trailer ISX 15 13 spd.
    I average just under 4mpg otr.
  3. Arctic_fox
    4,509
    25,471
    Sep 16, 2016
    2017 pete 579 end dump with an MX13 13 speed. I average around 6mpg currently HOWEVER i have only driven my truck 3900 miles as of this post. So small sample size.
  4. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    01 Mack Vision 460. Low gearing, 5mpg now, was 4mpg.
  5. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    Freightliner columbia cat c 13 dry van 6.6 mpg 10 speed ,3.55
  6. justcarhaulin
    justcarhaulin Light Load Member
    153
    238
    Jul 20, 2015
    2016 389 Pete with an isx pulling an 9 car easy loader. About 500k on dash mostly interstate. I've averaged 5.3 miles. My friend had the same set up and he also get the same mpg.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    97 W9, 550 kitty, 18 speed, 3.55s, pulling a hopper around 90k gross, gets a solid 5.5 average, sucks fuel like a 747 when the wind is blowing 40 mile an hour though.
  8. Banker
    Banker Road Train Member
    4,515
    14,628
    Aug 19, 2012
    2015 389 glider Detroit Series 60, 11 car Cottrell
    In warmer months I will just barely bump 5 loaded both ways running about the speed limits most of the time. 4.5-4.7 in the cold months. Mty 50% I can get 6 in the warm months. I recently checked my charge air cooler and it was leaking. I hope to bring the mileage up slightly with the new charge air cooler.
    Hammer166 Thanks this.
  9. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    2015 T800 Tri-Drive, 18 speed, 4.10 rear, 5MPG
  10. Brian_CEM
    4
    I'm basically the same set up as you but your mileage is much better. I need to do some digging. BTW what oil temps are you running fully loaded, on a straight and climbing a hill. Also how much oil do you burn?
  11. Brian_CEM
    4
    Any Volvo car hauler guys out there. I ran into a guy saying he was getting better than 6.
